Gas tank cleaning
john cervini /
I need to clean a magnum tank. It has a little rust but the bigger issue is black hard dried old gas/oil. I remember hearing something about pinesol but wanted some other options. Thanks!
Re: Gas tank cleaning
One or 2 handfuls of 1/2" or 1" drywall screws, shaken not stirred. Pour a few ounces of mineral spirits in there while you're shaking. Rinse, then use some evaporust, rinse again, and fill with premix.
♣Slew Foot♣ /
I have heard vinegar. Piss. Clr the works. Washing lye.
Ice cubes melt. Screws, bolts, nuts and the like do not(edited)
I have found when you finally have it cleaned spotless clean it atleast one more time ...there is still.some hideing somewhere in there
None of that is needed , unless there's more rust than metal .
You might try this :
https://www.mopedarmy.com/forums/read.php?6,4160423,4160423#msg-4160423
obviously you remove them when your'e done? i've done this to a dozen tanks, really not hard shaking 99% of them out and using a magnet for the last few.
Use an old piece of bike chain instead of loose nuts and bolts. Much easier to fish out.
Or you can go to a paint shop throw a guy $20 and he might let you put sand blasting hose down in there and it would look like inside of new moped tank after.
I have a few old dog leash chains I toss I the tank and swish around with gas. Works realy well. Easy to just dump out after.
john cervini /
I ended up using Pine Sol. I used 2:1 ratio of pine Sol and water. Let it soak for 3 days. No agitation or scrubbing. Dumped and rinsed this morning then dried with a hairdryer. Amazing results. Perfectly clean with zero flash rust!
Moped Lar (OFMC) /
If you have any Pine Sol left over, my mom used to use it to clean the crap stains off the inside of the toilet bowl. Worked and smelled great!
It also works good for cleaning ancient carbs . ;)
