Re: Suzuki fa50 low top speed need help, tried everything.
Dr. Mantis Toboggan M.D. /
You more than likely need to upjet you main jet. Looks like the stock jet is #77.5 but it's probably not stamped on your main jet with the clone carb you are using, see carb diagram. Buy a range of different sized main jets (maybe like an 80, 82, 85, 87 & 90) and switch them out until you get the best result. I would start working your way down from the largest jet size.
  Suzuki fa50 low top speed need help, tried everything.Topic by: justin fox justin fox 05/03/20 04:05AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: P D P D 05/03/20 09:24AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/03/20 11:04AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Michael Smith Michael Smith 05/03/20 10:22AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: P D P D 05/03/20 10:44AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/03/20 11:10AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/03/20 11:07AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Michael Smith Michael Smith 05/03/20 11:28AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/03/20 11:36AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/03/20 11:30AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Michael Smith Michael Smith 05/03/20 11:39AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: P D P D 05/03/20 12:01PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/03/20 12:25PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: P D P D 05/03/20 12:59PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/03/20 03:07PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: P D P D 05/03/20 03:40PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/03/20 09:40PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Jack Rutherford Jack Rutherford 05/03/20 10:39PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: P D P D 05/04/20 08:36AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/06/20 01:02AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Dr. Mantis Toboggan M.D. Dr. Mantis Toboggan M.D. 05/04/20 01:37PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/06/20 05:45PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: live ɘvil live ɘvil 05/04/20 05:31PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/06/20 01:03AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Stephen Keller Stephen Keller 05/06/20 10:24PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Cameron Cate Cameron Cate 05/06/20 06:53PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: live ɘvil live ɘvil 05/08/20 05:40PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Rob P Rob P 05/08/20 05:16PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/13/20 03:54PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/13/20 03:55PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Stephen Keller Stephen Keller 05/14/20 01:17AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: P D P D 05/14/20 08:37AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Stephen Keller Stephen Keller 05/14/20 12:04PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/14/20 09:46PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/14/20 09:43PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Rob P Rob P 05/11/20 12:47PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Pushrod Fifty Pushrod Fifty 05/11/20 04:17PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: live ɘvil live ɘvil 05/11/20 08:01PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/13/20 03:58PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/13/20 04:00PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Michael Smith Michael Smith 05/13/20 09:10PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/13/20 09:57PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Dr. Mantis Toboggan M.D. Dr. Mantis Toboggan M.D. 05/14/20 02:01PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/14/20 09:49PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Rob P Rob P 05/15/20 02:39AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Stephen Keller Stephen Keller 05/15/20 03:51AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Rob P Rob P 05/15/20 01:11PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/16/20 04:59AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Wet Truck Daddy Wet Truck Daddy 05/15/20 03:11AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Rob P Rob P 05/15/20 03:25AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Rob P Rob P 05/15/20 03:37AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Rob P Rob P 05/15/20 03:42AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Aaron Blair Aaron Blair 05/16/20 06:29AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: P D P D 05/16/20 08:31AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/16/20 05:16PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/16/20 05:17PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Rob P Rob P 05/18/20 12:54AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: punkrock randy punkrock randy 05/22/20 10:08AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 06/10/20 07:04PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Rob P Rob P 06/10/20 07:14PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Dr. Mantis Toboggan M.D. Dr. Mantis Toboggan M.D. 06/11/20 11:44AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 06/12/20 03:58PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 06/13/20 10:39AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Rob P Rob P 06/10/20 07:19PM
