Re: Suzuki fa50 low top speed need help, tried everything.
live ɘvil /
> Cameron Cate Wrote:
> That sound you keep refrencing is called four-stroking. Its doing that
> up top becuase it is too rich on the main jet. Get the main right an it
> will run clean in the higher rpms and youll be going faster. Read up on
> simple carb tuning and rejet accordingly.
> The problem with swapping og parts to the chinese clone is that the two
> units are not going to be manufactured to the same specs and its
> basically a craps shoot whether any swapped parts will actually work.
> Youre much better off finding an original carb.
> And stop saying you've done "everything" because you obviously haven't.
I agree but failed to touch on the four stroke sound hes hearing. If someone else had that carb apart to "clean" they may very well have enlarged the original main jet with a wire or jet drill.
  Suzuki fa50 low top speed need help, tried everything.Topic by: justin fox justin fox 05/03/20 04:05AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: P D P D 05/03/20 09:24AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/03/20 11:04AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Michael Smith Michael Smith 05/03/20 10:22AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: P D P D 05/03/20 10:44AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/03/20 11:10AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/03/20 11:07AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Michael Smith Michael Smith 05/03/20 11:28AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/03/20 11:36AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/03/20 11:30AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Michael Smith Michael Smith 05/03/20 11:39AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: P D P D 05/03/20 12:01PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/03/20 12:25PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: P D P D 05/03/20 12:59PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/03/20 03:07PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: P D P D 05/03/20 03:40PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/03/20 09:40PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Jack Rutherford Jack Rutherford 05/03/20 10:39PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: P D P D 05/04/20 08:36AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/06/20 01:02AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Dr. Mantis Toboggan M.D. Dr. Mantis Toboggan M.D. 05/04/20 01:37PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/06/20 05:45PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: live ɘvil live ɘvil 05/04/20 05:31PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/06/20 01:03AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Stephen Keller Stephen Keller 05/06/20 10:24PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Cameron Cate Cameron Cate 05/06/20 06:53PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: live ɘvil live ɘvil 05/08/20 05:40PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Rob P Rob P 05/08/20 05:16PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/13/20 03:54PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/13/20 03:55PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Stephen Keller Stephen Keller 05/14/20 01:17AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: P D P D 05/14/20 08:37AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Stephen Keller Stephen Keller 05/14/20 12:04PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/14/20 09:46PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/14/20 09:43PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Rob P Rob P 05/11/20 12:47PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Pushrod Fifty Pushrod Fifty 05/11/20 04:17PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: live ɘvil live ɘvil 05/11/20 08:01PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/13/20 03:58PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/13/20 04:00PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Michael Smith Michael Smith 05/13/20 09:10PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/13/20 09:57PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Dr. Mantis Toboggan M.D. Dr. Mantis Toboggan M.D. 05/14/20 02:01PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/14/20 09:49PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Rob P Rob P 05/15/20 02:39AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Stephen Keller Stephen Keller 05/15/20 03:51AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Rob P Rob P 05/15/20 01:11PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/16/20 04:59AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Wet Truck Daddy Wet Truck Daddy 05/15/20 03:11AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Rob P Rob P 05/15/20 03:25AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Rob P Rob P 05/15/20 03:37AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Rob P Rob P 05/15/20 03:42AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Aaron Blair Aaron Blair 05/16/20 06:29AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: P D P D 05/16/20 08:31AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/16/20 05:16PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 05/16/20 05:17PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Rob P Rob P 05/18/20 12:54AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: punkrock randy punkrock randy 05/22/20 10:08AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 06/10/20 07:04PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Rob P Rob P 06/10/20 07:14PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Dr. Mantis Toboggan M.D. Dr. Mantis Toboggan M.D. 06/11/20 11:44AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 06/12/20 03:58PM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: justin fox justin fox 06/13/20 10:39AM
  Re: Suzuki fa50 low top speed need help, tried everything.Re: Rob P Rob P 06/10/20 07:19PM
