The oil pump was being used until very recently when I stopped using it to check to see if that was causing my slow issue. Like I said earlier in the posts I feel like I've checked and changed everything on this moped lol. It runs the same plugged and unplugged tried it both ways. Also if and when i get this thing running correctly my mind says get rid of the stupid oil pump and i want to. But my issue is I've read that it ouls areas that the mixed gas doesnt cover? My only worry is that i will blow it up eventually if i dont run the oil pump. Am i correct or is it okay to just get rid of the pump and not worry about hurting the motor?
