weights. Bad you weren't closer I'd come by and get that thing running!
Re: Suzuki fa50 low top speed need help, tried everything.
> Rob P Wrote:
> Maybe bent carburetor flange? Find yourself a piece of thick plate glass
> or marble counter top. Put a sheet of 220 or 400 wet and dry with some
> light oil and work it flat just like lapping a cylinder head. You can
> see if its warped with just a few strokes. Always use figure eights.
This. Mine was so bent from over tightening the carb that I ended up replacing the intake and it worked perfectly. Sand it like Rob said unless it's too far gone.
Well we shall see. I installed the gasket again with both sides having make a gasket on it. Tonight it should be dry. If not have a spare fa50 I use for parts maybe that piece is still good. Will update you later when I see what happens tonight.
Okay so the gasket maker dried I adjusted the carburetor the 4 stroke sound is gone....only one minor problem.....it still only goes 16 mph....at that speed I could walk faster. Any ideas guys?
