Re: Suzuki fa50 low top speed need help, tried everything.
> Pushrod Fifty Wrote:
> If you didn't block the oil inject system youre pulling air into the
> crankcase. That foam is upholstery closed cell foam. Best to put
> everything back to stock and work with one variable at a time.
This is a golden rule with 40 year old antiques.
Hey there, okay so I reinstalled an original carburetor off of a different fa50 same thing runs exactly the same as the chinese carburetor. I currently have it running on mixed gas and just left the oil pump there but removed the oil tank....I had some gas leaks which I took care of and also had an electrical issue but all of that has been fixed. I am literally tired of working on this thing lol. I've replaced I think every part. Changed the case oil today. It could be an air leak that's something I've not checked. Any idea which lines those are or how do I check for air leaks?
Also sometimes it surges. Acts like it wants to go faster but then doesnt.
Here are some pics of my setup. If you see anything that I'm missing let me know.
Here are more.
A few thoughts.
The surging sounds like an air leak. I've had five FA50s and never had an air leak. Check it with the engine running and spray around the engine with carb cleaner. If it makes it stall there's an air leak there.
Check the carb. In the photo the bolt does not look tight (may be a illusion).
Also, the fuel cock is on reserve which will suck the fuel from the sump in the tank through the reserve fuel line. Could be setiment in the sump. Make sure fuel cock is on run.
Planning to spray the engine shortly. The bolt wasnt attached to the carb because part of the old carb is broken. I dont think it was leaking because on the new carb both bolts work fine and there is no difference. Also this was just something I tried, I removed the air filter and covered the carb intake slowly with my hand thinking that if there was an air leak giving it less air might make a difference. It just slowly ran worse and died. I watched videos today online of fa50s running and they run way better than mine does lol. Soon as I hit 17 mph it starts this farting sound and that's it no more speed. I have to be missing something. Gonna start with checking for air leaks next. See how that goes.
Last photo there is a nipple on the carb without a hose on it?!? What went there, maybe plug that up, is your filter open cell foam?
That is a vent . It should have a hose leading down under the motor .
If left as is , crud could get into the carb . (edited)
Also looks like an open port right above the (idle?) screw? When you get this sorted, next step is a new rear tire! Fender too if you still have it.
Dr. Mantis Toboggan M.D. /
You're more than likely sucking in air through the oil pump since you don't have the nipple plugged after you removed the oil line. Plug that up with vacuum cap and see how it runs. Also, if you're not using the oil pump and premixing instead then you should remove the internal gear that connects the oil pump to the transmission and reinstall the pump without it. You can also remove the entire oil pump and install a block off plate. Make your own or buy the one they have on Treats.
https://www.treatland.tv/MLM-suzuki-fa50-oil-injection-block-off-plate-p/mlm-fa50-oil-plate-1100.htm?gclid=EAIaIQobChMIk8H8gfez6QIVB43ICh2bDQuXEAQYASABEgJvJvD_BwE
I've no idea what that is. The original carburetor was the same way when I got it. And I have the original air filter, i dont know if the foam inside is original or not.
Oh I am planning on doing this thing up right if I ever get this issue fixed. New tires, cleaned up, etc. Just not gonna put any more money into it until I get the slow issue taken care of. Got some carburetor cleaner today, gonna try spraying it down tomorrow to see if there is an air leak and go from there.
The oil pump was being used until very recently when I stopped using it to check to see if that was causing my slow issue. Like I said earlier in the posts I feel like I've checked and changed everything on this moped lol. It runs the same plugged and unplugged tried it both ways. Also if and when i get this thing running correctly my mind says get rid of the stupid oil pump and i want to. But my issue is I've read that it ouls areas that the mixed gas doesnt cover? My only worry is that i will blow it up eventually if i dont run the oil pump. Am i correct or is it okay to just get rid of the pump and not worry about hurting the motor?
I've had numerous fa50and fz50s never ever had a problem with the oil pump! I really don't understand why some guys have an issue with it. All of mine ripped! Even had 1 that I ported the shit out of had boost ports shaved the deck and head , 3 or 4 base gaskets so the exhaust port is uncovered, that thing did 47mph. Still had the oil injection. My question is did this bike by any chance come from Iowa? Iowa bike only have 2 transfer ports not 3 and have a top speed of 20mph.
Sounds like an fa50... I've seen a few that run up to 20mph and then give out. I would do rebuild the top end with new gaskets and deck the head. Cook the stock pipe to clear out the carbon, or get a new one... Then i'd probably run a SHA with a new intake and see how that does...
Sha is junk! The 1st chance I get it's history. I'll stick with a mikuni better throttle response.
Found these on letgo you might wanna jump on it before they're gone. 2 Simonini pipes probably the best pipe ever made.
https://www.letgo.com/es-us/amp/i/2x-simonini-exhausts-suzuki-fa50-moped_71570893-f161-45e3-8af9-c99644f0a86d (edited)
These 2 images 1 is an iowa type cylinder with 2 transfers the other is 3 transfers.
^ never knew Suzuki did the Iowa thing...
I've only seen 1!
It's not an Iowa bike it came from New York city originally and I dont think the motor needs rebuilt I checked compression amd it's like 130 psi and the exhaust is fine I removed it and ran it no change amd installed a different fa50 exhaust still no change and I cleaned it.
Have you checked the crank seals?
Is the carb adjusted exactly to factory specs ?
Air leak guys?
That would be an air leak! Check the carburetor gasket as well as the intake to case gasket. That was the area you sprayed. Maybe even the base gasket.
punkrock randy /
Sucking in too much air(unmetered), not enough fuel. Causing the four stroking sound that you’re hearing. No longer to be referred to as “farting” sounds. Let us know how she rips after you get it sussed out :-)
Okay so this is an update. I finally got new gaskets for it and the one it looks like I'm having issues with is the carburetor gasket. I bought a new one and installed it today. Hit it with carb cleaner and it died. Any ideas why it would still be leaking air? I ordered a genuine suzuki gasket proper thickness etc. Shoukd I try make a gasket on the new gasket?
Maybe bent carburetor flange? Find yourself a piece of thick plate glass or marble counter top. Put a sheet of 220 or 400 wet and dry with some light oil and work it flat just like lapping a cylinder head. You can see if its warped with just a few strokes. Always use figure eights.
