QT50 Bogging - With Video
Garrett Jackson /
Son starting complaining that QT50 was getting hard to start and wouldn't restart after stopping. Wife said she noticed some smoke. I'd never changed crank seals on this one, so I did. First attempt after changing seals, it cranked perfectly, rode for about 5 minutes, it bogged and died. Watch the video. Spark is great, compression is fine, clear fuel line with good flow, spotless carb. What's the deal with this thing?
Bogging QT50
Re: QT50 Bogging - With Video
Garrett Jackson /
Bump. Could use some help.
Where's jack Rutherford when you need him ?
Kinda sounds like the CDI isn't being told to go from start to run on a 3 position ignition switch. So maybe bad connection somewhere or tired out CDI
Garrett Jackson /
I appreciate the thought, but does it matter that it's a 2 position switch? This is a 79 model.
Doesn't matter unless somebody put the wrong one in at some point.
Remove the muffler and it try again.
Jack Rutherford /
recheck your spark. in fact post a vid of your spark test
Tank not venting?
