Replacing Kinetic TFR jet
Jessie Paull /
Anyone know of an easy way to swap a the main jet on a TFR? Seems like the only way to get at it is to remove the muffler? Is this really the best way? (edited)
Re: Replacing Kinetic TFR jet
> best way?
Probably since the carb comes out the bottom.....
Dirty30 Dillon /
Carb doesn't have to come out the bottom.
You can pull the carb out through the space between the subframe and frame
Jessie Paull /
I ended up managing to get the float bowl off from the bottom without taking the muffler off. It was just a bit of a tricky angle to get the screw driver in there.
putting it back on gonna be harder.
Jessie Paull /
eh, equally sucky both ways.
