1978 Sachs - used to start with one crank. Won't start
Botis Snapstu /
New here, please be gentle. Bought a 1978 Sachs Surburban, cranking over and running fine until about a week ago. Went over original schematic which showed 3 wires coming out of the magneto, the magneto on this one has 5 wires and the green wire for the front/rear brakes was loose and hanging detached from the terminal block, have those reattached now and the last time it started all lights including brake lights were functioning as they should.
The guy I bought it from said it might be a carburetor issue, has an aftermarket carburetor on (pics attached). The engine did get a 70cc bore and piston and there's currently no air filter on it. Didn't stop it from starting up previously. There is confirmed spark, gas tank is full, petcock works and fuel is flowing. He said the compression lever is working fine and I've checked the bottom float and the transmission for proper movement and transmission fluid.
Any ideas to get this running again? I'm going to try removing all wiring from the terminal block except essential like kill switch just to see if I can get it to crank over. Only 636 miles on the odometer.
  1978 Sachs - used to start with one crank. Won't startTopic by: Botis Snapstu Botis Snapstu 05/29/20 12:02PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 05/29/20 01:29PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: pat splat pat splat 05/29/20 06:44PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Botis Snapstu Botis Snapstu 05/30/20 08:11AM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Nick Haber Nick Haber 05/30/20 08:33AM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Botis Snapstu Botis Snapstu 05/31/20 08:20PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Aaron Blair Aaron Blair 05/30/20 09:50AM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Botis Snapstu Botis Snapstu 05/31/20 08:24PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: pat splat pat splat 05/31/20 08:35PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Botis Snapstu Botis Snapstu 05/31/20 08:43PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: pat splat pat splat 05/31/20 11:13PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Botis Snapstu Botis Snapstu 06/01/20 10:03AM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: K Olena K Olena 06/01/20 02:03AM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: pat splat pat splat 06/01/20 11:00AM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Botis Snapstu Botis Snapstu 06/01/20 03:01PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Papa _ Papa _ 06/01/20 11:47AM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Botis Snapstu Botis Snapstu 06/01/20 01:04PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: pat splat pat splat 06/01/20 04:20PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Botis Snapstu Botis Snapstu 06/01/20 10:04PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: P D P D 06/01/20 10:28PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Born to be WillD Born to be WillD 06/03/20 04:17AM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: K Olena K Olena 06/14/20 09:40PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Born to be WillD Born to be WillD 06/19/20 12:51AM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Kevin Bishop Kevin Bishop 06/17/20 09:04PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: P D P D 06/18/20 08:08AM
