Re: 1978 Sachs - used to start with one crank. Won't start
Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F /
What jet are you running? often times people don't jet when putting on a cylinder kit, and that causes issues with starting and running. Also, put in a new sparkplug, since sometimes they will spark when outside of the engine, but not under compression. Run an air filter as well, its just good peace of mind knowing your engine won't be killed by a loose piece of gravel
  1978 Sachs - used to start with one crank. Won't startTopic by: Botis Snapstu Botis Snapstu 05/29/20 12:02PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 05/29/20 01:29PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: pat splat pat splat 05/29/20 06:44PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Botis Snapstu Botis Snapstu 05/30/20 08:11AM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Nick Haber Nick Haber 05/30/20 08:33AM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Botis Snapstu Botis Snapstu 05/31/20 08:20PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Aaron Blair Aaron Blair 05/30/20 09:50AM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Botis Snapstu Botis Snapstu 05/31/20 08:24PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: pat splat pat splat 05/31/20 08:35PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Botis Snapstu Botis Snapstu 05/31/20 08:43PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: pat splat pat splat 05/31/20 11:13PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Botis Snapstu Botis Snapstu 06/01/20 10:03AM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: K Olena K Olena 06/01/20 02:03AM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: pat splat pat splat 06/01/20 11:00AM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Botis Snapstu Botis Snapstu 06/01/20 03:01PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Papa _ Papa _ 06/01/20 11:47AM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Botis Snapstu Botis Snapstu 06/01/20 01:04PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: pat splat pat splat 06/01/20 04:20PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Botis Snapstu Botis Snapstu 06/01/20 10:04PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: P D P D 06/01/20 10:28PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Born to be WillD Born to be WillD 06/03/20 04:17AM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: K Olena K Olena 06/14/20 09:40PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Born to be WillD Born to be WillD 06/19/20 12:51AM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Kevin Bishop Kevin Bishop 06/17/20 09:04PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: P D P D 06/18/20 08:08AM
