Re: 1978 Sachs - used to start with one crank. Won't start
pat splat /
I like air filters as well, is there spark? if not then clean your grounds. if there is then squirt some premix in the hole to see if it'll fire for a few seconds, if it does then clean your carb.
  1978 Sachs - used to start with one crank. Won't startTopic by: Botis Snapstu Botis Snapstu 05/29/20 12:02PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 05/29/20 01:29PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: pat splat pat splat 05/29/20 06:44PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Botis Snapstu Botis Snapstu 05/30/20 08:11AM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Nick MBC Nick MBC 05/30/20 08:33AM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Botis Snapstu Botis Snapstu 05/31/20 08:20PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Aaron Blair Aaron Blair 05/30/20 09:50AM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Botis Snapstu Botis Snapstu 05/31/20 08:24PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: pat splat pat splat 05/31/20 08:35PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Botis Snapstu Botis Snapstu 05/31/20 08:43PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: pat splat pat splat 05/31/20 11:13PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Botis Snapstu Botis Snapstu 06/01/20 10:03AM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: K Olena K Olena 06/01/20 02:03AM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: pat splat pat splat 06/01/20 11:00AM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Botis Snapstu Botis Snapstu 06/01/20 03:01PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Papa _ Papa _ 06/01/20 11:47AM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Botis Snapstu Botis Snapstu 06/01/20 01:04PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: pat splat pat splat 06/01/20 04:20PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Botis Snapstu Botis Snapstu 06/01/20 10:04PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: P D P D 06/01/20 10:28PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Born to be WillD Born to be WillD 06/03/20 04:17AM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: K Olena K Olena 06/14/20 09:40PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Born to be WillD Born to be WillD 06/19/20 12:51AM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: Kevin Bishop Kevin Bishop 06/17/20 09:04PM
  Re: 1978 Sachs - used to start with one crank. Won't startRe: P D P D 06/18/20 08:08AM
