I opened the carb, checked the float - it was all clean. The spark plug I cleaned. When I take it out of the cylinder it usually has a light coat of oil on it. If you mean the rubber o-ring in the carb that was fine and intact. (edited)
Re: 1978 Sachs - used to start with one crank. Won't start
