Hello guys, so I was having displacement valve problems and I tried to fix it by removing the valve assembly and putting a bolt in instead. I plugged it up with Loctite thread lock but now the bike wont accelerate. It idles pretty well (sometimes cuts out still) but I can't get it to accelerate! It lurches occasionally then back to idle even at full throttle. I'm admittedly a little new to all this but I think the bike just might not be getting a proper seal? Either that or I messed something up tightening the clutch cable... I need this to be working by Monday so I can get to work, any advice? Thank you so much!
Sachs Westlake not accelerating after removing displacement val
