Re: Sachs Westlake not accelerating after removing displacement val
C Basta /
Forgot to mention, it started and ran fine starting cold and it went a good 5-10 minutes before it died. I took the new bolt out and added more Loctite then the same thing happened. I tried putting a bit more slack in the clutch cable and that didn't help... I'll try starting it cold again in ~30 mins
