new coil, new spark plug wire, new cap, good ground, just no spark, only thing I have not replaced in condenser....could that be it??
puch, no spark, opinion please
Re: puch, no spark, opinion please
could be horn circuit or a bad ground.
You can test points and HT Coil. Eliminate what you can. Ground, no paint, clean steel.
ht coil use a ohm meter to test primary, secondary, cap and wire. Points closed .001.
bypass horn all in Wiki.
thank, might be getting back to you
clean the points really well and make sure they are opening , check your grounds and make sure the spades on the horn are hooked up , if it still doesn't fire then your condenser has gone out , i just had the condensers go out on both of mine in the same week , they are 30+ years old capacitors they are probably dried out
Unplug the horn, and ground the wires. Then try.
For real.
Read this completely especially 3/4 way down on servicing/maintaining magneto
