Re: Snapped a cylinder bolt - looking for suggestions to remove it
Michael Branscombe /
easy outs kind of suck, the taper is too short and they strip and don't grip well, I've found other ones with a better taper at the hardware store that have worked when easy outs fail.
use a center punch, and then drill it a little, reverse the drill and just the bit may get it to spin out … put some penetrating oil on the bolt, so the threads will let go of their grip.
your only real risk of damage is hitting the threads, but if you drill carefully, you should be good. It would also be a decent idea to chase the threads on those with a tap if/when you get it out. I'd just do them all if you do it to clean them up and keep things consistent.
  Snapped a cylinder bolt - looking for suggestions to remove itTopic by: Jessie Paull Jessie Paull 06/13/20 02:49PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: pat splat pat splat 06/13/20 03:11PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Jessie Paull Jessie Paull 06/13/20 03:45PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Bob Naske Bob Naske 06/13/20 03:58PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Jessie Paull Jessie Paull 06/13/20 04:01PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Chris Straub Chris Straub 06/13/20 04:08PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: pat splat pat splat 06/13/20 04:44PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Pushrod Fifty Pushrod Fifty 06/13/20 06:12PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Michael Branscombe Michael Branscombe 06/14/20 02:37PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Tim Doll Tim Doll 06/14/20 09:06PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Steven Davis Steven Davis 06/14/20 10:17PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Michael Branscombe Michael Branscombe 06/15/20 01:22AM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: P D P D 06/15/20 08:44AM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Kevin Bishop Kevin Bishop 06/17/20 08:50PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Michael Branscombe Michael Branscombe 06/18/20 09:43PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Mark Kinsler Mark Kinsler 06/21/20 05:09PM
