Re: Snapped a cylinder bolt - looking for suggestions to remove it
Steven Davis /
+1 on easy outs sucking, especially the squared shank ones. Get Screw extractors instead—WAY less likely to snap off inside the stuck bolt—available at good hardware stores. They work the same as an easy out, but won’t make your already sucky situation even worse. VERY hard to get out a broken off high carbon steel tip from a snapped off easy out. Combined with Kroil and some sharp drill bits, you can get that thing as the other guys described with the right sized extractor
  Snapped a cylinder bolt - looking for suggestions to remove itTopic by: Jessie Paull Jessie Paull 06/13/20 02:49PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: pat splat pat splat 06/13/20 03:11PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Jessie Paull Jessie Paull 06/13/20 03:45PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Bob Naske Bob Naske 06/13/20 03:58PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Jessie Paull Jessie Paull 06/13/20 04:01PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Chris Straub Chris Straub 06/13/20 04:08PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: pat splat pat splat 06/13/20 04:44PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Pushrod Fifty Pushrod Fifty 06/13/20 06:12PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Michael Branscombe Michael Branscombe 06/14/20 02:37PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Tim Doll Tim Doll 06/14/20 09:06PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Steven Davis Steven Davis 06/14/20 10:17PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Michael Branscombe Michael Branscombe 06/15/20 01:22AM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: P D P D 06/15/20 08:44AM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Kevin Bishop Kevin Bishop 06/17/20 08:50PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Michael Branscombe Michael Branscombe 06/18/20 09:43PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Mark Kinsler Mark Kinsler 06/21/20 05:09PM
