Re: Snapped a cylinder bolt - looking for suggestions to remove it
P D /
I'd try using a sharp pick to hopefully spin the piece out , first .
Easy outs can work and I've had 'some' luck with them .
I will caution anyone that attempts to use them to be very careful to not set them too hard into the intended piece , as that can easily spread/mushroom the piece , making it much harder to remove . Use just enough force to get a decent starting grip for the easy out .
  Snapped a cylinder bolt - looking for suggestions to remove itTopic by: Jessie Paull Jessie Paull 06/13/20 02:49PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: pat splat pat splat 06/13/20 03:11PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Jessie Paull Jessie Paull 06/13/20 03:45PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Bob Naske Bob Naske 06/13/20 03:58PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Jessie Paull Jessie Paull 06/13/20 04:01PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Chris Straub Chris Straub 06/13/20 04:08PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: pat splat pat splat 06/13/20 04:44PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Pushrod Fifty Pushrod Fifty 06/13/20 06:12PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Michael Branscombe Michael Branscombe 06/14/20 02:37PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Tim Doll Tim Doll 06/14/20 09:06PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Steven Davis Steven Davis 06/14/20 10:17PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Michael Branscombe Michael Branscombe 06/15/20 01:22AM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: P D P D 06/15/20 08:44AM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Kevin Bishop Kevin Bishop 06/17/20 08:50PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Michael Branscombe Michael Branscombe 06/18/20 09:43PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Mark Kinsler Mark Kinsler 06/21/20 05:09PM
