Re: Snapped a cylinder bolt - looking for suggestions to remove it
Kevin Bishop /
I understand the centerpunch technique but it will just jam an aluminum bolt in worse. Use the smallest left hand drill bit from harbor freight to make your pilot hole. Aluminum cuts easy and then step up to larger bits. You aren’t necessarily trying to drill it out completely. If you go slow,I mean by hand slow, you will feel it release and walk out. PB blaster or marvel oil helps and a quick blast with a torch to the case around it. God sake man cover the transfers. You might have to step up until you are same diameter as the inside of threads. The remaining threads will just fall out. Whatever you do chase that when done.
  Snapped a cylinder bolt - looking for suggestions to remove itTopic by: Jessie Paull Jessie Paull 06/13/20 02:49PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: pat splat pat splat 06/13/20 03:11PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Jessie Paull Jessie Paull 06/13/20 03:45PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Bob Naske Bob Naske 06/13/20 03:58PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Jessie Paull Jessie Paull 06/13/20 04:01PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Chris Straub Chris Straub 06/13/20 04:08PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: pat splat pat splat 06/13/20 04:44PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Pushrod Fifty Pushrod Fifty 06/13/20 06:12PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Michael Branscombe Michael Branscombe 06/14/20 02:37PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Tim Doll Tim Doll 06/14/20 09:06PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Steven Davis Steven Davis 06/14/20 10:17PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Michael Branscombe Michael Branscombe 06/15/20 01:22AM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: P D P D 06/15/20 08:44AM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Kevin Bishop Kevin Bishop 06/17/20 08:50PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Michael Branscombe Michael Branscombe 06/18/20 09:43PM
  Re: Snapped a cylinder bolt - looking for suggestions to remove itRe: Mark Kinsler Mark Kinsler 06/21/20 05:09PM
