Sachs wont fire
Sachs 505d wont run. Great spark. Seems to have compression. Wont start.
80 athena
Hpi
15mm bing
If the seals are junk would it still fire?
Re: Sachs wont fire
If you don't know their condition , it's time to replace them so you do know .
Do a leak down . That will show you where any leaks are .
Re: Sachs wont fire
I found out why my bike wont run.
Piston melted by the ring set pin. Scored and toasted the cylinder.
Oh well. Ordered 80cc Athena Reed kit
Re: Sachs wont fire
Why was the pin and ring ends going directly over a port ?
That should never happen .
Re: Sachs wont fire
Way the kit is.
Re: Sachs wont fire
Would be nice if they make the ring gap slide on a solid surface
Re: Sachs wont fire
No way i'd run something like that .
Either use a different kit or change the pin location on that kit .
Who ever designed that had their head where the sun doesn't shine .
Re: Sachs wont fire
What kits dont do this?
Re: Sachs wont fire
You sure that piston wasn't upside down? I've seen many kits, and the most basic thing from an engineering perspective when making a kit is to make sure the pin is not over a port.
Re: Sachs wont fire
The kit has a port on top and bottom. Im pretty sure i installed the piston correctly.
look at my slop!
Re: Sachs wont fire
i support the piston upside down assumption: i can almost convince myself i see the arrow on the piston head (which should point toward the exhaust) on the opposite side as that smear
Re: Sachs wont fire
There are no arrows in the piston swoop
Re: Sachs wont fire
Then put the piston in the cylinder bottom. Line up the cutouts in the cylinder skirt with the cutouts in the piston skirt . They should be an obvious match . That's how the piston should fit on the rod .
Mark the piston so you know which is the exhaust side . Maybe a scratch inside the piston skirt .
Re: Sachs wont fire
Good advice man
