Re: Is my jury rig causing the issue?
Trent Anderson /
Not sure about your fix or if that affects pedaling.
What oil are you using in the clutch bath?
Minarelli recommends ND20. It can be hard to find so many use ND30. Non Detergeant oil isn't supposed to foam up. The bubbles could be if you are not using the right oil.
