E50 ignition cutting out at medium to high revs
Hello.
My E50 is cutting out at high revs, it's definitely ignition as I can hear a pop on occasion. It has the standard points ignition and changing the plug hasn't made a difference. Ive disconnected the grounding wire to eliminate that and no difference. Guessing what's left are the HT coil, condenser and points so will start swapping them out. Just wondered if anyone had an idea what I should swap first, I'm thinking condense.... cheers!
Re: E50 ignition cutting out at medium to high revs
you need a new condenser and you might as well do the points while your at it.
Overpriced Parts /
You probably don’t need nothing but maintenance,
Read this completely especially the part 3/4 of the way down on page
https://www.mopedarmy.com/wiki/Puch_timing
Thanks Jeff
Thanks Ken
Hello chaps.
I have replaced and gapped the points, checked timing OK at 17 degrees BTDC, replaced condenser and also tried swapping out the ignition coil, spark plug and spark plug lead and cap. I have checked the condition of the stator wiring and disconnected the kill wire from the kill switch.
It is still cutting out. What I notice is when it does, I only get the ignition back if I ease off the throttle, if I open the throttle more then it won't come back. I know this symptom kind of point to fuelling but it is definitely ignition (good pops out of the exhaust when it happens).
Any ideas?
Thanks, Rich.
♣Slew Foot♣ /
Did you run it in the dark w/o covers?...
Hello slew foot, why do you ask? Cheers.
did you ground your ignition coil?
Yeah it's grounded, it's the european style ignition 2 lighting coils and ignition coil all mounted to the stator plate as shown in attached photo. Cheers.
I think Slew was asking because a failing condenser can cause arcing at the points, which would be noticeable in the dark.
get some og points, lube the cam n felt too.
Andrew Fleetwood /
Swap the plug cap and see what happens. These break down on air cooled engines, and was the most recent cause of breakdown on mine with the exact same symptoms as yours. I now carry a spare....
Is your neck tight? Is ur front fender touching the plug boot and shorting it out?
Thanks guys for the pointers.
I exhausted all avenues with the ignition, then decided to revisit the fuelling and removed the 15mm Bing and put a 17.5mm Dellorto PHBG from another moped on it, the issue has gone and now it rips. Had a quick look and looks like the Bing float needs some adjustment or I get another Dellorto as it is so much nicer!
Cheers, Richard.
Pushrod Fifty /
Had those symtoms when I put a piston in upside down once. Also had popping sounds at deceleration when my carb was too lean.
yeah I've also experienced popping with a mikuni vm when the needle is very lean
