Re: Is a stock e50 hi torque base gasket same size as aluminum
Overpriced Parts /
They made different sizes per hp size, sometimes they had no head gaskets initially from the factory but after the first service Most service people put a head gasket on,
Try to find the thinnest one like .;2mm but most Like Treats 50cc ones has .4mm size or do what I do, sand head flat, removing the compression rings then use .4mm head gasket for a noticeable power gain
