Re: Is a stock e50 hi torque base gasket same size as aluminum
Aaron Blair /
You shouldn't need an alu base gasket for any stock puch cylinder. The alu ones are made to space up the cylinder to fully clear the exhaust port on performance cylinders with different port timing. As far as I know anyway.
I have never bought a base gasket. Always made them out of cereal boxes. Need a little more spacing? Double em up. Never had a problem.
That being said, I have used aluminum base spacers.
