> Mike Boyd Wrote:
> OP is talking about the different stock Puch cylinders- High Torque
> (cast iron) vs Aluminum. He is asking if the paper/fiber base gasket
> should be the same for both setups. I understand the word aluminum is
> confusing in this context but he is not talking about making an aluminum
> base spacer or gasket, nor is he talking about making an aluminum head
> gasket. Let's use some reading comprehensions skills ffs.
> The answer is yes from the factory they are the same size, but as always
> check your exhaust port piston head clearance at BDC
No need for any worries about any differences , if you or he cuts your or his own base gaskets , FFS . ;) (edited)
