A restoration shouldn't be called such if you don't open up the motor and replace the 42 year old bearings and rubber seals.
Look at the spark plug, what jet is in your carb? You put a new carb on instead of cleaning the old one, did you make sure it had the same jet as the original? My guess is you're fouling plugs or your carb is dirty.
