Re: Tomos LX engine 70 cc blowout. Need help anyone have tips?
Dirty Mike /
Read the wiki, you need to take the clutch cover off, remove clutch bell/ clutches, then remove the shaft with the big first/second gears. There is a circlip that holds the thing on that holds the one way bearings, also a sprag clip that preloads those bearings. Order a new sprag or two to have on hand, and a gasket for your clutch cover because yours will most likely tear when you pull the cover
