Rollers
The rollers on the right are my used ones I pulled out of my taotao 50cc gy6
When I bought the moped the rollers on the left came with it. I just want to know if these would even be able to work as rollers considering they aren't even fully round.
Re: Rollers
Dirty30 Dillon /
They're Dr. Pulley Sliders.
Re: Rollers
Dr. Mantis Toboggan M.D. /
The orange ones on the left are slider roller weights. The design should work better than the standard circular rollers depending that they're the correct width and weight for your setup. You should weigh each set of rollers so you know what you're dealing with. I just got a set of those same 6 gram sliders for my prebug Zuma with a Stage 6 variator and they're working well so far. Just make sure you install them correctly.
Re: Rollers
Make sure you install the sliders correctly ;)
Re: Rollers
Thank you for the help!!
