The orange ones on the left are slider roller weights. The design should work better than the standard circular rollers depending that they're the correct width and weight for your setup. You should weigh each set of rollers so you know what you're dealing with. I just got a set of those same 6 gram sliders for my prebug Zuma with a Stage 6 variator and they're working well so far. Just make sure you install them correctly.
