Re: Shortcut Method to Bleeding Oil Injection in Urban Express?
P D /
> Amodo Ko Wrote:
> Are you referring to the oil control lever
> that you hold open only while the engine is running to bleed the system?
Sorry for misleading you .
I just did a short study of the urban oil pump .
It doesn't have a bleed outlet , other than the inlet and outlet nipples/ports .
Most oil pumps I've worked with have a bleed screw .
Anyway , the procedure in the service manual seems as effective , albeit , a bit more involved .
Maybe this would work :
Leaving the line connected to the oil tank , disconnect the line from the carb , while leaving both lines connected to the pump . Then lightly pressurize the oil tank while holding the pump control lever at the full open position . Continue that until no bubbles are present in either of the lines . Then reconnect the line to the carb while its oozing oil .
Catch the oil in a bowl or some such .
Seems to me that pushing oil through the entire 'system' would accomplish no air bubbles in a less messy way , with a bit less work .
If that doesn't work , you're left with the procedure in the manual .
Please post which method you used and your results . (edited)
