Re: Ciao - Cleaned the carb now it won't idle :(
Dirty30 Dillon /
> Seth B Wrote:
> It’s highly recommended to put an o-ring between that shim & the carb
> body to prevent air leaks.
100% not needed, just make sure your shim is intake and you seat the carb. The airleak comes in through the gap in the clamp mount, which is completely covered if you have the correct shim, undamaged. The oring is useful on carbs where that shim doesn't exist, a la Puch Bing's.
