Re: I rebuilt my Za and now it sounds like shit
Probably Fred /
Yeah that seems like somethings out of whack! did you drop your crankshaft!
how does the crank look on the inside trans side? Is there a proper clearance between the lobes and the crank and the crank case?
Does it have zero wiggle When running,
Is the top end perfect at the crank pin, is the bearing the correct width and size?
