I rebuilt my Za and now it sounds like shit
Wesley Ambrosini /
So this is it running without the trans.
I had a new rod pressed in
Crank ended up measuring cheek to cheek as close to my old crank as I could accurately measure with my calipers.
Reassembled to case, stock thickness gasket, tourqued the case bolts.
Put the motor in a vise, used machinist dial, couldn't get an accurate reading on the play, basically zero. Crank feels smooth no binding
Put on a kit directly off my e50 that this motor is replacing.
This is the motor, rope started, with no trans parts in it
Anywho just listen to this shit
Re: I rebuilt my Za and now it sounds like shit
You sure the flywheel is torqued? Everything ok behind it? How does it now spin by hand?
Wesley Ambrosini /
Flywheel is torqued and I just lapped it
Spins great with the top end on and off. Like perfect.
I knew the rebuild went too smooth my first thought before I started it was "I don't know what all the fuss is about za rebuilds aren't so bad"
What if you removed the flywheel, took out the plug, spin it with an electric drill and check run out on the crank? Maybe uncle Ken knows what's up?
I just rebuilt one of these too. Haven't fired it yet. Hope I'm not in the same boat. Hope you get this sorted. (edited)
Wesley Ambrosini /
Something is going on with the flywheel. I must have have put it on like a jackass in a rush because even lapped it sheared the key not its out if round as fuck. With the flywheel off its smooth with it on it hits and grinds
Nice! Glad you found it. Shit happens. I did something similar with a Tomos but was able to salvage it.
Maybe without the trans it is unbalanced? Hook it all up and try again? No resistance may lead to noisy play?
How close did you get the crank to true? How did you true it? Did you replace both bearings? You have to replace the inner and outer races not just one
Wesley Ambrosini /
The crank was sent to Mr. crankshaft so it was trued and polished and all that shit.
The roffman method is run it without a trans so I don't think it would goof it up.
Yeah I replaced the outer races and cages the whole deal
I’m guessing your shimming is off then. Take it apart and fix it!
Wesley Ambrosini /
That's what I'm thinking. It has zero wiggle, doesn't bind, I thought I lucked out but I guess not.
Overpriced Parts /
Yeah that seems like somethings out of whack! did you drop your crankshaft!
how does the crank look on the inside trans side? Is there a proper clearance between the lobes and the crank and the crank case?
Does it have zero wiggle When running,
Is the top end perfect at the crank pin, is the bearing the correct width and size?
Wesley Ambrosini /
Ok, outta the woods probably
Just got it running.
Looks like a typical chain of errors
So I rattled the flywheel on in a hurry
That destroyed the key
Key chunks got into the flywheel magnets and that was what was chunking
Lapped the crank to a different flywheel
Runs great.
Still have to do the trans end float but at least the crank is OK
