I’ve tried an impact, a strap wrench and an adjustable wrench to get it off
Blasted it with liquid wrench and it’s not budging. Am I missing something? Or is it just ON there good
Trying to swap to a tjt
It's just ON THERE. Get someone to hold the strap wrench so you can get two hands on the socket, applying pressure/weight towards the variator while turning. It'll go
Got it! Gave it a good wack and used a strap wrench and impact and it came off
Going to hijack my own thread rather than starting a new one. Are there any intakes that will work to run a 15SHA besides dremeling out the stock intake?
Not off the shelf, you'd have to weld something up. It is kind of strange that mlm doesn't make 15/16mm sha intakes for pp derbis. They could make them so the carb still lines right up with the stock center cover choke button.
Yeah, I was looking. I wish they did. That would be sweet
