Re: Maxi Tail Light
Mike Boyd /
Factory wiring is grey is tail light, green or blue/green is brake light. Make sure you have correct voltage and wattage bulbs across the whole system, check your brake light switches are properly working, check the ground connection is free of paint etc. Whenever I do a full rebuild I run a ground wire from the back fender to the motor instead of relying on the frame ground as well.
