Maxi Tail Light
Christian Parks /
Bought a new treats tail light
https://www.treatland.tv/CEV-tail-light-with-license-plate-bracket-p/cev-tail-light-19317.htm
Brake light is bright and working fine. Tail light,nothing.
I tried two different bulbs and still nothing.
Any advice?
Thanks
Re: Maxi Tail Light
Richard Eberline /
Bad light coil, switch bulbs and try. Then switch bulbs back to original position. Now switch gray and green light coil wires. Now you know.
Re: Maxi Tail Light
Christian Parks /
Its my understanding, blue light for taillight and grey for brake light. I get very very dim taillight sometimes but brake light works fine.
Re: Maxi Tail Light
Check your headlight. It might be too many watts.
Re: Maxi Tail Light
Christian Parks /
No luck, headlight is 6v 21 w
Re: Maxi Tail Light
Factory wiring is grey is tail light, green or blue/green is brake light. Make sure you have correct voltage and wattage bulbs across the whole system, check your brake light switches are properly working, check the ground connection is free of paint etc. Whenever I do a full rebuild I run a ground wire from the back fender to the motor instead of relying on the frame ground as well.
