Re: Airbox filling with oil
Michael Branscombe /
a lot of two strokes just do that, even with them tuned right and carb cleaned and set up well. it is a little spit back - what you can do is take the airbox off and run it for a minute, if it is just a little fine mist - not bad, if it is spray that splatters - your carb needs work or something else is off. if it is just the mist - most of it just gets sucked back in and burned up, the oil your finding is just what was as a little oil settled out of the fuel. if it doesn't run poorly and it is a fine mist, you'll probably make yourself crazy or make the issue worse by trying to fix it.
