Hi there! Recently got this 1981 jawa x30 (207? 210? Something) for pretty cheap.
Freed up the motor and discovered that it has pretty weak spark (you can see it but its razor thin, and you have to spin up the motor pretty fast to get anything)
And knowing jawas, it has a very complicated ignition, and im not sure where to start, changed the plug, same thing. Guessing it's the coil or the thryster. As the alternator works for the headlights (this is the one with the black 4 wire box and the silver cylinder coil)
Any input on where to get parts as well? Only thing on treatland is tires.
Thanks again!
