Re: Pug 103 brake light blowing. Robbing spark when not blown
cheetahchrome . /
Well the blue wire was grounded to one of the bracket bolts. At some time someone had built another identical ground wire on the other bracket bolt. I actually just put a socket on the grounding wire I chose to use and wormed it back and forth to be sure that the bolt/wire was digging into the metal of the fender to create a clean grounding path. That cured the bottleneck of electrons that was wreaking havoc on the brake light bulb element and robbing the spark from the plug.
  Pug 103 brake light blowing. Robbing spark when not blownTopic by: cheetahchrome . cheetahchrome . 06/22/20 01:05AM
  Re: Pug 103 brake light blowing. Robbing spark when not blownRe: cheetahchrome . cheetahchrome . 06/22/20 01:19AM
  Re: Pug 103 brake light blowing. Robbing spark when not blownRe: Keno Rojas Keno Rojas 06/22/20 01:49AM
  Re: Pug 103 brake light blowing. Robbing spark when not blownRe: cheetahchrome . cheetahchrome . 06/22/20 07:53AM
  Re: Pug 103 brake light blowing. Robbing spark when not blownRe: pat splat pat splat 06/22/20 08:51AM
  Re: Pug 103 brake light blowing. Robbing spark when not blownRe: cheetahchrome . cheetahchrome . 06/22/20 09:24AM
  Re: Pug 103 brake light blowing. Robbing spark when not blownRe: cheetahchrome . cheetahchrome . 06/22/20 09:38AM
  Re: Pug 103 brake light blowing. Robbing spark when not blownRe: cheetahchrome . cheetahchrome . 06/22/20 09:41AM
  Re: Pug 103 brake light blowing. Robbing spark when not blownRe: cheetahchrome . cheetahchrome . 06/22/20 09:57AM
  Re: Pug 103 brake light blowing. Robbing spark when not blownRe: pat splat pat splat 06/22/20 10:26AM
  Re: Pug 103 brake light blowing. Robbing spark when not blownRe: cheetahchrome . cheetahchrome . 06/22/20 10:49AM
  Re: Pug 103 brake light blowing. Robbing spark when not blownRe: cheetahchrome . cheetahchrome . 06/22/20 11:28AM
  Re: Pug 103 brake light blowing. Robbing spark when not blownRe: cheetahchrome . cheetahchrome . 06/22/20 11:34AM
  Re: Pug 103 brake light blowing. Robbing spark when not blownRe: cheetahchrome . cheetahchrome . 06/22/20 11:43AM
  Re: Pug 103 brake light blowing. Robbing spark when not blownRe: cheetahchrome . cheetahchrome . 06/22/20 11:56AM
  Re: Pug 103 brake light blowing. Robbing spark when not blownRe: pat splat pat splat 06/22/20 12:10PM
  Re: Pug 103 brake light blowing. Robbing spark when not blownRe: cheetahchrome . cheetahchrome . 06/22/20 12:47PM
  Re: Pug 103 brake light blowing. Robbing spark when not blownRe: Keno Rojas Keno Rojas 06/22/20 03:59PM
  Re: Pug 103 brake light blowing. Robbing spark when not blownRe: cheetahchrome . cheetahchrome . 06/22/20 06:15PM
  Re: Pug 103 brake light blowing. Robbing spark when not blownRe: P D P D 06/23/20 08:39AM
  Re: Pug 103 brake light blowing. Robbing spark when not blownRe: cheetahchrome . cheetahchrome . 06/23/20 09:43AM
  Re: Pug 103 brake light blowing. Robbing spark when not blownRe: P D P D 06/23/20 03:49PM
