OEM Gasket Or gasket maker from a tube?
Oil leaking from right side crankcase on QT50. Gaskets ordered, but I have some high temp silicone gasket maker. Do some people use both? Curious to what you’ve found to be the best method
Re: OEM Gasket Or gasket maker from a tube?
Hepatitis J [OFMC] /
Don't use silicone. soak the gasket in oil before installing it. Torque to spec
(edited)
