Bing 15mm
New not clone bing 15mm carb. Seems like the slide is only going up half way when pulling cable not hitting WOT. I know choke isnt stopping it. Whats the little washer thing under spring do?
Re: Bing 15mm
Wesley Ambrosini /
Is the cable cut to the correct length. Maybe the slide has a defect that is catching the key that keeps the slide straight
Re: Bing 15mm
maybe your throttle is maxed out.
Re: Bing 15mm
Testing on bench. Slide works fine until secure top down with spring then its like 1/4 throttle maybe half. Nothing in wrong i just dont know bout slide washer under spring it just sits there?
Re: Bing 15mm
Wesley Ambrosini /
That keeps the needle in place I believe, either way a tiny washer isn't restricting 1/2" of throttle.
Re: Bing 15mm
What is the bike? I know that the later puch throttles dont work with the old cables.
Re: Bing 15mm
77 maxi. New bing 15mm new cable from treats maxi party pack
Re: Bing 15mm
The cable is too short. had the same issue. get the cut to length cable.
Re: Bing 15mm
Thanks man I figured I couldnt be the only one with this issue
