Tomos turn signals not properly functioning
When I try to use my signals, they don't work; at higher RPMs, the headlight seems to flash. 2007 Tomos Targa LX. Thoughts?
Re: Tomos turn signals not properly functioning
Just tested again, signals work at high RPM, headlight also flashes.
Do those models have a battery or maybe supposed to have a battery?
Nope no battery.
can u turn ur idle up any without the rear wheel spinning like crazy
Has it always had this sickness or did it start happening?
I have a Kinetic that I swapped out the headlight bulb because the low beam quit. Mistakenly put in a 6V bulb when it called for a 12V.
Wonked out the whole system. Headlight flashed the turns were very dim and the tail light was dim with no brake light.
Switched it back to the 12V bulb all is ZEN now (edited)
