PA50 carb bowl drain direction...
Steve Parsons /
I've cleaned the carb on my barn find PA50 2 (caked in old gas...licensed last in 1982), with help from your cab cleaning tutorial. On the subject of what direction the bowl drain tube points, it says "to the right when bowl assembled" (source: Frankman). Ok....which "right"? Based on direction of airflow thru carb, with carb in it's normal upright position? Or...? The service manual shows it to left, with carb in its normal position. ??? The tutorial say the bowl will go in either position but installed wrong there will be "problems". ???
Thank you!
Re: PA50 carb bowl drain direction...
The service manual shows the wrong way. The drain tube does point to the “right”-as in the same side that the choke is on. Hope that helps
When a manual says left or right , it assumes you know front from back .
Steve Parsons /
Thanks! Ive had problems getting the fuel to flow into the carb, so maybe putting the float bowl installed as pictured may result in interference between float and drain pipe, causing float to stick.
Steve Parsons /
Manual does not say left or right....just the drawing
The stock hobbit kehlin carbs are finicky as hell. I've been in the position to think I had a fuel flow issues many times when it turned out the carb was just dirty.
They have all sorts of places for shit to hide and I've had completely clean looking kehlins stop fuel flow.
I've got a three step operation now... Clean throughly with compressed air and solvent. Pretend I put it on the bike and it was still fucked up, drink beer...repeat two more times (edited)
Emil Kniemel /
I wish they would just say passenger side!
But , there is no passenger side on a bike . ;)
And , most folks kinda know right from left . LOL
Lolol...but is it right or left sitting on it or standing in front of it ??? Leaves questions unanswered ..haha
Well , the bike was designed to mostly move in a forward direction and to be sat on facing where we are mostly going . That is the position right and left should be derived from . Hopefully , we know where the front of the machine is . ;) (edited)
> P D Wrote:
> it
Haha. You might be hopeing too much with some folks ..lol..too much to think about
> think about
Ha . Seems that process may be totally absent in at least a few cases . ;)
