Alright, so what you just said is what I have always known to do. I've never personally done the honing, but I have been told to run up to hardbor and grab this little device that doesnt so much hone as it does clean everything propperly.
This brings me to yesterday, I call a place that's done a bunch of PW engines and run by them what's going on and he tells me, "If your cylinder looks good, buff the carbon out of the the head and the top of the piston, DO NOT TOUCH the cylinder walls with anything, throw in a new set of rings and bolt her back up."
So you are of the opinion that running the device through the cylinder for 3-4 minutes is a good idea? I hate conflicting advice when the one I've always practiced seems right, but the person I hear the other from is experienced....
Maybe you're him, but do we have a master QT50 Engine builder around here???
> P D Wrote:
> You're measuring the very top edge of the bore .
> That's the part that rarely wears any at all .
> Much better to take measurements incrementally down through the complete
> bore .
> Like at the 1/4 , then 1/2 and 3/4 down .
> Normally the bore will be a touch larger at the bottom .
> You can do the same on the piston .
> By the time you're done , you'll know the piston to bore clearance (
> important information ) .
> If you install new ring(s) , be sure to hone in a decent crosshatch or
> the new will not seat .
