Re: Rebuilding an 84/79 QT50
P D /
Ha . That looks almost as bad as the piston I'm running in my FA50 right now .
You could measure what you have and order an appropriate sized piston and rings .
Or simply clean what you have and run it .
Sand the high spots off the piston wall . Clean the ring landings and dome .
Run a quick hone through the cylinder to clean that .
Be sure that every thing is free of any debris and put it back together .
  Rebuilding an 84/79 QT50Topic by: Geoffrey C Geoffrey C 07/18/20 10:18PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/18/20 10:21PM
  Re: Rebuilding an 84/79 QT50Re: Jack Rutherford Jack Rutherford 07/19/20 01:29AM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/20/20 09:11PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/20/20 09:52PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/20/20 10:32PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/21/20 12:17AM
  Re: Rebuilding an 84/79 QT50Re: P D P D 07/21/20 07:45AM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/22/20 08:35AM
  Re: Rebuilding an 84/79 QT50Re: P D P D 07/22/20 09:07AM
  Re: Rebuilding an 84/79 QT50Re: Jack Rutherford Jack Rutherford 07/22/20 12:52PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/21/20 05:05PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/22/20 09:26AM
  Re: Rebuilding an 84/79 QT50Re: P D P D 07/22/20 09:51AM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/22/20 12:04PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/22/20 12:05PM
  Re: Rebuilding an 84/79 QT50Re: P D P D 07/22/20 12:38PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/22/20 01:01PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/22/20 09:20PM
  Re: Rebuilding an 84/79 QT50Re: P D P D 07/23/20 08:09AM
  Re: Rebuilding an 84/79 QT50Re: Jack Rutherford Jack Rutherford 07/25/20 10:55AM
  Re: Rebuilding an 84/79 QT50Re: Jack Rutherford Jack Rutherford 07/25/20 11:13AM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/25/20 05:52PM
  Re: Rebuilding an 84/79 QT50Re: Jack Rutherford Jack Rutherford 07/25/20 07:19PM
  Re: Rebuilding an 84/79 QT50Re: Stephen Keller Stephen Keller 07/31/20 11:09PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 08/01/20 01:40PM
  Re: Rebuilding an 84/79 QT50Re: Jack Rutherford Jack Rutherford 08/01/20 03:13PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 08/01/20 05:16PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/23/20 10:40AM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/24/20 01:49PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/24/20 07:38PM
  Re: Rebuilding an 84/79 QT50Re: Stephen Keller Stephen Keller 07/24/20 10:21PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/24/20 10:39PM
  Re: Rebuilding an 84/79 QT50Re: Stephen Keller Stephen Keller 07/25/20 12:59AM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/25/20 12:27PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/25/20 12:57PM
  Re: Rebuilding an 84/79 QT50Re: Jack Rutherford Jack Rutherford 07/25/20 02:57PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/27/20 02:43PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/27/20 08:20PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/27/20 08:41PM
  Re: Rebuilding an 84/79 QT50Re: P D P D 07/27/20 09:35PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/27/20 09:56PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/28/20 09:56PM
  Re: Rebuilding an 84/79 QT50Re: Mark Kinsler Mark Kinsler 07/29/20 12:21AM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/29/20 06:58AM
  Re: Rebuilding an 84/79 QT50Re: Mark Kinsler Mark Kinsler 07/29/20 01:08PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/29/20 01:11PM
  Re: Rebuilding an 84/79 QT50Re: Mark Kinsler Mark Kinsler 07/29/20 01:16PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/29/20 07:34PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/29/20 09:58PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/30/20 11:56PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/31/20 10:20PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 08/01/20 05:17PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 08/02/20 09:13PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 08/02/20 09:26PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 08/07/20 09:43PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 08/09/20 02:53PM
