Re: Rebuilding an 84/79 QT50
Geoffrey C /
So although I’d cleaned the engine very well apparently I didn’t do it good enough. So I put new gaskets and a cylinder and head as well as engine covers back on, put the oil pump back on as a seal and will be steam cleaning tomorrow.
I found a tiny tiny chip just where the right side engine cover meets the case toward the front of the bottom. I’m going to get this repaired, don’t need any air leaks or oil leaks(it was holding oil fine so it may not be much to it but I’m going to investigate more.
  Rebuilding an 84/79 QT50Topic by: Geoffrey C Geoffrey C 07/18/20 10:18PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/18/20 10:21PM
  Re: Rebuilding an 84/79 QT50Re: Jack Rutherford Jack Rutherford 07/19/20 01:29AM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/20/20 09:11PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/20/20 09:52PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/20/20 10:32PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/21/20 12:17AM
  Re: Rebuilding an 84/79 QT50Re: P D P D 07/21/20 07:45AM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/22/20 08:35AM
  Re: Rebuilding an 84/79 QT50Re: P D P D 07/22/20 09:07AM
  Re: Rebuilding an 84/79 QT50Re: Jack Rutherford Jack Rutherford 07/22/20 12:52PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/21/20 05:05PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/22/20 09:26AM
  Re: Rebuilding an 84/79 QT50Re: P D P D 07/22/20 09:51AM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/22/20 12:04PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/22/20 12:05PM
  Re: Rebuilding an 84/79 QT50Re: P D P D 07/22/20 12:38PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/22/20 01:01PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/22/20 09:20PM
  Re: Rebuilding an 84/79 QT50Re: P D P D 07/23/20 08:09AM
  Re: Rebuilding an 84/79 QT50Re: Jack Rutherford Jack Rutherford 07/25/20 10:55AM
  Re: Rebuilding an 84/79 QT50Re: Jack Rutherford Jack Rutherford 07/25/20 11:13AM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/25/20 05:52PM
  Re: Rebuilding an 84/79 QT50Re: Jack Rutherford Jack Rutherford 07/25/20 07:19PM
  Re: Rebuilding an 84/79 QT50Re: Stephen Keller Stephen Keller 07/31/20 11:09PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 08/01/20 01:40PM
  Re: Rebuilding an 84/79 QT50Re: Jack Rutherford Jack Rutherford 08/01/20 03:13PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 08/01/20 05:16PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/23/20 10:40AM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/24/20 01:49PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/24/20 07:38PM
  Re: Rebuilding an 84/79 QT50Re: Stephen Keller Stephen Keller 07/24/20 10:21PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/24/20 10:39PM
  Re: Rebuilding an 84/79 QT50Re: Stephen Keller Stephen Keller 07/25/20 12:59AM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/25/20 12:27PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/25/20 12:57PM
  Re: Rebuilding an 84/79 QT50Re: Jack Rutherford Jack Rutherford 07/25/20 02:57PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/27/20 02:43PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/27/20 08:20PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/27/20 08:41PM
  Re: Rebuilding an 84/79 QT50Re: P D P D 07/27/20 09:35PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/27/20 09:56PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/28/20 09:56PM
  Re: Rebuilding an 84/79 QT50Re: Mark Kinsler Mark Kinsler 07/29/20 12:21AM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/29/20 06:58AM
  Re: Rebuilding an 84/79 QT50Re: Mark Kinsler Mark Kinsler 07/29/20 01:08PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/29/20 01:11PM
  Re: Rebuilding an 84/79 QT50Re: Mark Kinsler Mark Kinsler 07/29/20 01:16PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/29/20 07:34PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/29/20 09:58PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/30/20 11:56PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 07/31/20 10:20PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 08/01/20 05:17PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 08/02/20 09:13PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 08/02/20 09:26PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 08/07/20 09:43PM
  Re: Rebuilding an 84/79 QT50Re: Geoffrey C Geoffrey C 08/09/20 02:53PM
