You can hear the fuel/oil tank ring(no bolts still got to run the harness), sounds like motor noise it isn’t.
Need wheel bearings brakes, a new single throttle cable the choke kept causing grief so I removed and capped the cable inlet for now. I’m happy with it. Huge improvement over how I got it. Tires. Got to get tires. (edited)
