Re: NC50 battery not charging
Jack Rutherford /
Finally a use for all those ac adapters I’ve saved over the years ! Sounds like your qt is not charging the battery.
Just tested battery voltage with multimeter without recharge. Read in at 2.24volts. When installed in the bike and revved it will jump up to 4 or more volts but then drop back down to the original 2.24 volts. Tested the rectifier and it's good and has just recently been replaced
All connections are tight and clean. Made sure that the ground by the taillight was clean and shiny. Are there other ground points on an 82? Also I'm not very comfortable nor confident in taking apart anything involving the flywheel or stator
