Re: JCP Swinger 2 timing and results
Jay Rivett /
Super rich...
You can move down a jet and see if that helps. If you do not have any jets you can at least lean out the needle on your slide. Moving the clip up will lean ot out. Just move one notch at a time. If you are on the top notch and it is still to rich, you will need to invest in some jets. Get a few of them to play with and find the perfect one.
