Thanks for the response! Damn clone carb...I did order the mlm velocity stack air filter with the jets the other day, think that’ll work? Also got a 224 atomizer because there weren’t any 222’s on treats.
As far as the timing, I did set it according to that wiki. I used a screwdriver though so it may be a little off but I marked and re-marked the actual screw driver when searching for tdc to try and make it accurate. Will go back and check again and get a timing light before jetting.
Got the original JCP bill of sale from ‘79 and I can’t remember exactly but thought it said 2hp on there, will have to double check. Cleaned the exhaust pipe of a lot of deposits, no huge buildup but it needed a wire brush scrubbing. Thanks again! Will update when the parts come in and send some shots!
